sergiusn
Registrado em: 19 Fev 2010, 10:07
Promax Performance X-Chip
Mensagem por sergiusn »
Blz pessoal!
Zapeando pelo ebay vi algo interessante por US$24.99:
http://cgi.ebay.com/ebaymotors/Performa ... ccessories
Alguém já ouviu falar ou instalou esse chip PROMAX (Performance X-Chip for CITROEN)? Promete economia de combustível e ganho de potência (cerca de 25HP para os motores 2.0 e 18HP para os 1.6L) sem prejudicar o veículo.
(Não tenho interesse em colocá-lo. Apenas curiosidade!)
Abs!!!!!!!!
Item location: EUROPE, EU, Germany
"This is Real Performance Chip version X-Chip just hitting the market!
It is a one easy step and ready to go kit.
In less than 15 minutes of quick and easy installation, and you are all set to have fun.
PROMAX version of X-Chip will give your car a higher performance by increasing both Horsepower and Torque.
X-Chip have 3 mode:
PERFORMANCE
CITY DRIVE
FUEL ECONOMY
First one (PERFORMANCE) mode will add Max Power Performance about 10-40% of REAL increase Horsepower and Torque depends on your engine type and model, second one (FUEL ECONOMY) mode will actually reduce fuel charge on 20-30% of Fuel/Gas saved. And last one newest (CITY DRIVE) mode specially designed to rise overall performance of the engine with this mode you will still have better fuel economy and increased Nm, Torque, throttle response, acceleration and HP in the full RPM range. GUARANTEED !!!
PROMAX X-Chip will reprogram your car engine ECU and release full Potential Power of engine. X-Chip have only 5-7 wires that you need connect to ECU (Easy PLUG-IN Job), so very simple to install also step-by-step instructions included with the X-Chip !!!
So what are you waiting for?
Will not harm your vehicle !
Will not void any warranty !
Simple and quick to install, remove, and reinstall !
No tools required !
Frequently Asked Questions:
Q: Does your X-Chip work on Turbo Engines?
A: Yes X-Chip works well on Turbo Petrol and Turbo Diesels (TDi HDi Di Ti FSI T...) engines.
Q: Does PROMAX X-Chip work on diesel cars?
A: Yes X-Chip works well on modern with an ECU Diesel engines.
Q: Are this PROMAX X-Chip easy to fit?
A: This item comes with full detailed fitting instructions so really easy to fit and we will help with installation process !
Q: Will this actually work?
A: Yes it will do exactly what is stated in the list.
Q: Hi I am interested how this chip works?
A: PROMAX X-CHIP connected directly to ECU sensors (MAF/MAP/IAT/O2) by playing with this sensors we can change ECU stock parameters.
Q: Will it harm my car in any way?
A: No it will not effect your car's health at all.
Q: How long does it take for dispatch?
A: It will take up to 3 working days for dispatch and about 5-10 working days for delivery.
Re: Promax Performance X-Chip
Eu não acredito nestas coisas. Milagres não existem!
Depois passe em "Novos Membros" e faça a sua apresentação.
MarcoVTS
Registrado em: 22 Dez 2008, 19:48
Mensagem por MarcoVTS »
KKKKKKKKKKKKK 25HP... acho que nem se eu investir R$ 3000 consigo chegar nisso.
*****EX - C4 VTS 180CV*****
sergiusn
Como não conheço a engenharia do motor e sua eletrônica eu prefiro dar o benefício da dúvida e ser ponderado.
O interessante seria ver um teste prático do motor sem e com esse chip. Enfim, uma avaliação profissional com equipamentos profissionais que possa dizer: (1) sim, o chip cumpre o que promete, ou (2) sim, o chip cumpre PARCIALMENTE o que promete ou (3) Não, esse chip é pura fantasia e não cumpre o que promete, nem parcialmente.
Abs.!!
sergius, eu não sou nenhum expert em motor, mas pelo pouco que conheço, já dá pra saber que estes produtos que são oferecidos na internet prometendo grandes ganhos de potência por preços pequenos, são pura enganação. Se vc quiser mexer na eletrônica do carro, remapeando a injeção, vai ter que recorrer a empresas ou engenheiros especializados nisto, que possuem os programas originais de cada carro, e conseguem alterar estes parâmetros para outros mais eficientes. E só este serviço fica em torno de R$ 800,00, sem que vc consiga muita coisa além de uns 15 HP. Não perca seu tempo ou dinheiro com isto. Depois, com certeza alguns companheiros que entendem bem deste assunto, podem postar e explicar melhor esta questão pra nós.
Registrado em: 11 Mar 2009, 18:45
Mensagem por Thyago Szoke »
Não tem segredo. Andar mais e beber menos não depende de fatores relacionados a software, mas sim à parte técnica.
É como o Unichip: se fosse tão bom quanto falam, viria de fábrica equipando o carro.
GuiTrocca
Registrado em: 22 Jan 2010, 19:05
Mensagem por GuiTrocca »
É.... eu q não vou instalar primeiro pra dizer hehehehe
Acho q pra ganhar 30 hp tem q suar e MUITO( no dinheiro principalmente)
Vlww
Citroen VTR Prata
Corre que é golpe.
RodVTS98
Mensagem por RodVTS98 »
Sergius.
Já pesquisei um pouco sobre esses chips baratos que são vendidos por aí e existem 3 opções de equipamentos que essas empresas desenvolvem e vendem:
1- Um simples resistor que altera a leitura do sensor de temperatura de admissão do motor. Quando mais fria a leitura, mais a ECU adianta o motor injetando mais combustível, então vc sente o carro andar mais. O efeito deveria ser parecido com aquele que vc sente quando vc anda com o seu carro numa noite fria e num dia quente e ensolarado. Já percebeu como seu carro anda mais na noite fria? Só que, a difrença é que na noite fria vc ainda tem um ar mais frio (de verdade) e mais denso, por isso o resultado é melhor que só enganar a ECU com esse resistor.
2- Uma placa eletrônica que modifica a leitura do sensor de temperatura. Dá o mesmo resultado que o resistor descrito acima, mas é mais elaborada.
3- Uma placa eletrônica que modifica a leitura da sonda lambda (sensor de oxigêncio), enganado a ECU dizendo que os gases que estão saíndo no escapamento indicam mistura pobre. Por isso, a ECU vai corrigir a mistura, adiantar ponto de ignição e injetar mais combustível para compensar essa leitura falsa. O resultado será um carro com mais torque. Algo parecido com o efeito dado pelo resistor.
IMPORTANTE: Nenhum desses dispositivos dão 25cv a mais no motor! O consumo pode piorar, dependendo da sua forma de condução e, infelizmente, vc vai ficar achando que tem esses 25cv a mais, o que é uma pura enganação!
Ou seja, se quer melhorar um pouco seu carro, parta para uma reprogramação feita por profissionais sérios. Vc nunca terá +25cv no seu motor só fazendo isso, mas terá um carro mais agradável de dirigir e sem enganar a ECU, o que pode lhe trazer prejuízos a longo prazo.
Abraço,
Rodrigo.
sergiusn
Oi Rodrigo, Td blza?
Eu tbém fui dar uma googleada nesses chips!
Foi apenas curiosidade e não tenho interesse em chipar o C4 Pallas que na minha opinião já tem motor demais e seria pura tolice fazer algo do tipo segundo o meu estilo. Como sou um tio tranquilo e do tipo "passeio" o alto torque e os 151CV do pallas são suficientes e respondem bem às minha necessidades.
Agora a parte de economia de combustível é sempre bem-vinda! hehe
Em todo caso é um assunto interessante para os BadBoys!
ABS!!!
